What happens while IT Integration
gurwinkle
I have two companies IT Integration.
What happens on networking side of the things.
There are two routers at the front and then firewall and switches.
I want to use VPN to integrate the two sites.
What will happen at collaboration tier or only VPN would be sufficient.
Francesco Molino
What do you mean by collaboration tier or only VPN?
If you build a VPN between those 2 sites, you'll be able to bring reachability between them. Now, there's something I'm missing, why did you tag this post with MPLS?
Do you have any MPLS network existing on those sites?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
It would have gone in VPN but I put in MPLS by chance.
So VPN would be enough.
