07-28-2017 03:53 PM
How do I setup a VIP in front of the postgresql servers for CC HA?
Solved! Go to Solution.
07-31-2017 06:04 AM
Hi Rajaram,
You just need a Virtual IP which can be used for CCM to connect to the database. If you are setting up in AWS it could be your Elastic IP or public IP which is permanent.
Please refer to below URL
http://docs.cloudcenter.cisco.com/display/CCD48/CCM+HA
HA Virtual Appliance Architecture - Version 4.8 - CloudCenter Docs
Vihar Kuruppathukattil
07-29-2017 03:26 PM
Well, looks like I over-thought this. Just needed an available IP Address.
07-31-2017 06:04 AM
Hi Rajaram,
11-20-2019 10:33 PM
Hi Team,
I have a few queries about Cisco cloud center 5.0.
11-21-2019 03:33 AM
5.0 runs in Kubernetes with masters already in HA.
Running full HA Pods is a feature that is coming shortly.
So the infrastructure itself (Kubernetes) already runs in HA if you have the installer install it. If you install K8S yourself then it is your option to either run a singular master (non-HA) or masters in HA. If you run HA , it is best practice from K8S to run 3+.
Does that answer your question? You said "queries" but I only saw one.
