Static IPAM in CloudCenter
longlh12
Hello Cloudcenter experts,
i have private vmware cloud added to the Cloudcenter, IPAMCallout is set.
i also added this directory in the 3 CCOs: /usr/local/osmosix/callout/ipam
with callout.conf:
                                   name=ipam
                                   type=exec
                                   topic=ipam
                                   debug=true
                                   executable=run.sh
                                   reinject=true
                                   disabled=false
and run.sh
                        #!/bin/bash
                              echo "DnsServerList=8.8.8.8,8.8.4.4"
                              echo "nicCount=1"  # This is a mandatory parameter and is always set to 1
                              echo "nicIP_0=10.14.102.30"
                              echo "nicDnsServerList_0=8.8.8.8,8.8.4.4"
                              echo "nicGateway_0=10.14.102.1"
                              echo "nicNetmask_0=255.255.255.0"
                              echo "domainName=fiscloud.vn"
                              echo "hwClockUTC=true"
                              echo "timeZone=Canada/Eastern"
                              echo "osHostname=testhost1"
but when deploying the application profile (its just single VM deployment), IP Allocation mode is still DHCP:
subnetId=FIS_ISC|FIS_ISC-AppProfile|VLAN-102-DEV2-EPG (vDS-UCSD)
eNV_cliqrExternalHttpsEnabled=0
FullClone=true
CloudFamily=Vmware
eNV_Cloud_Setting_cloud=VMWARE-Keangnam
eNV_Cloud_Setting_nicInfo=[{"privateIPAllocationMode":"DHCP","nicNetworkType":"NETWORK","networkID":"FIS_ISC|FIS_ISC-AppProfile|VLAN-102-DEV2-EPG (vDS-UCSD)","order":1,"publicIpAllocate":false,"assignIpv6Address":false}]
CC_AUTO_SELECT_NETWORK=false
eNV_cliqrSSLCert=
eNV_suspendScript=
eNV_tierOrder=1
eNV_launchIdent={user}cliqradmin{group}{vendor}1
eNV_Cloud_Setting_UserDataCenterName=Fis-Cloud
Name=test5
eNV_Cloud_Setting_FullClone=true
eNV_cliqrExternalPreStopAction=
eNV_cliqrNonStandardPort=
eNV_cliqrForceHttpRedirect=0
eNV_samlAuthDomain=10.14.60.213
UserClusterName=Lab-Mgt-Cluster
eNV_bareMetalMachine=false
eNV_SharedStorageMount=/shared
eNV_Cloud_Setting_subnetId=FIS_ISC|FIS_ISC-AppProfile|VLAN-102-DEV2-EPG (vDS-UCSD)
eNV_CliqrDepEnvId=1
eNV_cliqrExternalPostStartAction=
eNV_cliqrExternalPreInitAction=
numNICs=1
eNV_JOB_ID=10
eNV_appPackage=
eNV_OSSVC_HOME=/usr/local/osmosix/service
eNV_launchUserId=2
eNV_parentJobId=9
eNV_Cloud_Setting_UserResourcePoolName=FIS_ISC_ResourcePool
eNV_topTier=true
eNV_cliqrCentOSPreStopAction=
eNV_cliqrAppTierName=CentOS_1
eNV_Cloud_Setting_UserDatastoreCluster=Data_P5_Fast_vol4
eNV_Cloud_Setting_UserDatastore=
eNV_imageName=CentOS 6.x
eNV_Cloud_Setting_CloudFamily=Vmware
eNV_cliqrAppType=n-tier
eNV_cliqrExternalHttpEnabled=1
eNV_currentTierJobId=10
eNV_SSHPreference=NO_PREFERENCE
eNV_cliqrCentOSPreStartAction=
eNV_pathParamNames_app_30_order_0=cliqrCentOSPreStartAction,cliqrCentOSPostStartAction,cliqrCentOSPreStopAction,cliqrCentOSPostStopAction,cliqrExternalPreStartAction,cliqrExternalPreInitAction,cliqrExternalPostStartAction,cliqrExternalPreStopAction,cliqrExternalPostStopAction,suspendScript,resumeScript
eNV_cliqrCentOSPostStopAction=
eNV_resumeScript=
eNV_cliqrExternalNoProtocolEnabled=0
eNV_Cli
Did i misconfigure something? pls help!
Hope to see ur reply.
Rui Vieira
have you restarted the cco? it wont "see" your change until it is restarted.
mohammedb1
When making a change to the VMhostname or IP Addressing behaviour for any cloud region, you need to firstly re-activate the orchestrate through the GUI or API.
The new settings should then take effect.
