the CSRv comes with 3 Interfaces , how can i add the 4th Interface
Ibrahim Jamil
Level 6
Level 6
Hi Guys
6 Replies 6
balaji.bandi
Ethernet network interfaces: Three or more virtual network  interface cards (vNICs), up to the maximum allowed by
the hypervisor
Depends on what hyper-visor you using you need to add interface to CSRv (Turn off , add new interface and turn on)
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_01010.pdf
BB
Hi Balagi
thanks for ur reply
I m using VMware workstation 12
sh ip int brief shows ONLY G1 ,G2 G3 , I m using the below , i think it needs LIC to unlock more interfaces :(
actually i need up to 4 interface
csr1000v-universalk9.16.09.02.ova
thanks
Cisco offers you 60days trail license if you like to get one for you.
BB
Hi Balaji
can u pls check from ur end if CSRv shows more interface on VMworkstations
balaji.bandi
I am running under KVM, and Esxi, quick test i have booted in KVM here is the details.
Router#show version
Cisco IOS XE Software, Version 16.03.01
Cisco IOS Software [Denali], CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.3.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 02-Aug-16 18:36 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 1 minute
Uptime for this control processor is 3 minutes
System returned to ROM by reload
System image file is "bootflash:packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ax
License Type: Default. No valid license found.
Next reload license Level: ax
cisco CSR1000V (VXE) processor (revision VXE) with 1081760K/3075K bytes of memory.
Processor board ID 903J6D6TKGE
5 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3019208K bytes of physical memory.
7774207K bytes of virtual hard disk at bootflash:.
0K bytes of at webui:.
Router#show ip interface brief
GigabitEthernet1 unassigned YES DHCP up up
GigabitEthernet2 unassigned YES unset administratively down down
GigabitEthernet3 unassigned YES unset administratively down down
GigabitEthernet4 unassigned YES unset administratively down down
GigabitEthernet5 unassigned YES unset administratively down down
BB
Thanks for ur reply
i dont know bro , why mine shows ONLY 3 interfaces on VMworkstation 12 :(
I tried to edit the vmx file , but didnt work either
