802.1x between Switch 3750 and ACS 4.2 Authentication faild --need help
stevenxu89
I configured the Switch 3750 and ACS for 802.1x authentication.
when I used the windows as the 802.1x client, it prompted "click here to enter user name and pasword for the network " as normal.
The problem is that after I entered username and password (i am sure i enter the identical username and password as in ACS) the authentication failed,
What is the most possibly problem?
Thx in advance!!!
The configuration is Sw3750 is:
aaa new-model
aaa authentication login default local
aaa authentication enable default line
aaa authentication dot1x default group radius
aaa authorization network default group radius
dot1x system-auth-control
interface GigabitEthernet1/0/18
description Link to test 802.1x
switchport access vlan 119
switchport mode access
dot1x pae authenticator
dot1x port-control auto
spanning-tree portfast
radius-server host 10.1.1.333 auth-port 1645 acct-port 1646
radius-server source-ports 1645-1646
radius-server key keepopen0
In the ACS:
Network Configuration -->aaa client ip address: 10.1.119.1(the vlan 119's ip address), shared secret: keepopen0
user setup -->real name:test1, password: test1.
Attached is the debug information
Jagdeep Gambhir
Level 10
Level 10
What do you see in acs failed attempts?
