02-17-2020 11:35 PM - edited 02-21-2020 11:13 AM
I would like to ask about multi-auth.
I want to run 802.1x wired authentication. i have 2960 switch port ge0/1 connected to dump switch port ge 0/1. All hosts and printer are connect to other port of dump switch .I want to run 802.1x on 2960 port.
I want to use multi authentication.I user PEAP protocol and using user name and password for authentication.
I run multi authentication for all host and MAB for printer.I create different profiles in NAC.Let me know
It may apply separate profile for each hosts and printer ?
OR It may apply only one profile for every host which connected to dump switch because of we are using 1 port of 2960 ?
Do i need to add MAC of dump-switch in Allow -MAC profile of NAC ?
Solved! Go to Solution.
02-18-2020 05:29 AM
02-18-2020 01:20 AM
02-18-2020 04:29 PM - edited 02-18-2020 09:30 PM
It mean should i use one authentication method in one port? Is not support 802.1x and MAB together with multi-host in one port? When i tested,result is ok ? all device are authenticate .
But i would like to know can i use MAB and 802.1x togetther ? Firstly i will check MAB ,if it is passed check 802.1x again.I want to check MAC and 802.1x credential for all devices.
02-18-2020 05:29 AM
02-18-2020 04:33 PM
02-21-2020 02:24 PM - edited 02-23-2020 12:19 PM
I feel you are confusing our readers/experts. 😉
Cisco Flexible Authentication may support MAB and DOT1X in the same switch interface. The following are good references:
Also, please ensure the dumb switch is supporting EAP pass-through.
