AAA pix problem
richard.gosling
Level 3
Level 3
Hi All
From the PDM I can't change the AAA server to inside from outside, I get the following error.
Also issuing the no command from CLI does not work
[ERR]no aaa-server RADIUS (outside) host *.*.*.* cisco timeout 10
you must remove all AAA corresponding entries prior to
charrellc011699
Community Member
Hi. This means that the server *.*.*.* is referenced either by a AAA server group or in some other way in use. I ran into the same issue and had to remove all the "accounting include" or "authentication include" statements that were referencing my server before I could remove the server definition and recreate it.
HTH,
Curtis
