aaa problem with 2621XM Ver 12.2 IP Plus
larrys
I cannot setup AAA on a 2621XM Ver 12.2 IP Plus router
the configuration appears as follows which looks strange.
Please advise if this is correct for 12.2 software.
aaa new-model
aaa authentication login default group tacacs+ enable none
aaa authentication ppp default group tacacs+
aaa authorization exec default group tacacs+
aaa authorization network default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
Any assistance would be greatly appreciated
Many Thanks
Larry_s
mhoda
Level 5
Level 5
Hi Larry_s,
The configuration looks ok. Which part you are confused about? What is not working? Whats the requirement? Thanks,
Mynul
Should there be an ! mark between the aaa new-model reference & the resst of the statement.
Larry_s
Larry,
This ! is fine on the config. This shouldn't affect any thing. Thanks,
Mynul
Many Thanks
Mynul
I will investigate the ACS Side of things further.
larry_s
