Acquiring Upgrade Software for ACS Solution Engine
bwmcfarlane
Community Member
We have a couple of ACS 1112's running 3.2.3, and we would like to upgrade these to the most current version of software that is supported on this h/w platform. I see in the downloads that we can get the 3.3 software. How do we get anything more recent than that?
Jagdeep Gambhir
Level 11
Level 11
For recent acs software you need to open a TAC case. ACS software's are not listed on CCO.
Also you need to purchase it.
~JG
Do rate helpful posts
