ACS 3.2 authentication with NDS using EAP-TLS
jverkerke
Community Member
Hi all,
I am currently working on ACS 3.2 to authenticate with external Novell NDS. I was able to authenticate it using Cisco supported card and wlan utility. With this set up, this can authtenticate using PEAP-GTC, but not EAP-TLS. I would like to use native Windows XP client wlan utility to use EAP-TLS, but It doesn't work. Is there any issue using NDS to authenticate EAP-TLS? Is there any pathes for windows client to make them work?
It is clearly specified in the documentation that external databse Novell NDS supports EAP-TLS.
Please help...
jverkerke
Community Member
Additional information from the above question.
I have the following setup;
ACS 3.2(3) built 11 appliance
-Cisco AP1200 wireless access point
-Novell NDS to be used as an external database
-Windows 2003 enterprise with standalone Certificate Authorithy Services Installed
-Windows XP SP2 Client
My Goal is to use Windows XP Native Wlan Utility to connect to AP using EAP-TLS authentication against Novell NDS.
Tried to connect using Cisco compatible wlaN utility and authenticate using EAP-GTC against Novell NDS for for users, it works fine and perfectly.
When connecting using EAP-TLS, I am getting an error from ACS failed attempt "Auth type Not supported by External DB". But in the ACS documentation says that it supports EAP-TLS. How true is this? Is there anybody have the same problem? Do I need to upgrade my ACS? What should I do? What other authentication type could be used to utilize native WinXP Wlan Utility?
Please help...
rene.schmid
Level 2
Level 2
hi,
did you have any eap-tls configuration now running with novell ca ??? I have the same problem...
any news???
regards
rene
Premdeep Banga
Level 10
Level 10
Try configuring NDS as LDAP rather than NDS on ACS. (In latest version of ACS, NDS can only be configured as Generic LDAP)
Prem
