ACS 3.2 limited command authorization problem
shawn.stone
Community Member
I am trying to set up a command authorization set that will allow a group to configure and change loopback interfaces, but no other interfaces. Currently, once I allow configure, I cannot limit what interface they can change. It's either complete configure access, or none.
I have set up the command set like this:
-unmatched commands = deny
-permit unmatched arguments is UNCHECKED in both cases
Configure
permit terminal
Interface
permit ^loopback
aaa group server tacacs+ tsg1
server x.x.x.x
aaa authentication login default group tacacs+
aaa authentication login vty group tsg1
aaa authentication enable default enable
aaa authorization exec default group tsg1
aaa authorization exec vtyauth group tsg1
aaa authorization commands 0 default group tacacs+
aaa authorization commands 1 default group tacacs+
aaa authorization commands 15 default group tacacs+
aaa session-id common
tacacs-server host x.x.x.x
tacacs-server timeout 20
tacacs-server directed-request
tacacs-server key labrat1
radius-server authorization permit missing Service-Type
Could someone please tell me what I am missing?
gfullage
"aaa authorization commands ...." works only on commands in exec mode. Once you enter config mode this authorization has no effect and the user will be able to do anything.
Add the following command to also enable authorization for config mode commands:
aaa authorization config-commands
and you should be good to go.
gfullage
That did it! Thanks for the help!
