06-06-2005 04:19 AM - edited 03-10-2019 02:10 PM
I have an existing ACS 2.X. We are using a 2610 router for the dial up access. All dial up access are working.
When I setup a new machine for the new ACS 3.3.And changed the tacacs server host ip, I could not make the dial up connections working. What seems to be wrong?
Listed below is the configuration of the router.
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname fwdialup
aaa new-model
aaa authentication login default tacacs+
aaa authentication login no_tacacs enable
aaa authentication ppp default tacacs+
aaa authentication ppp tacacs+ if-needed
aaa authorization exec default tacacs+
aaa authorization network default tacacs+
aaa accounting exec default start-stop tacacs+
aaa accounting network default start-stop tacacs+
enable secret 5
enable password 7
username anton
username michelle
memory-size iomem 20
clock timezone EST 8
ip subnet-zero
interface Ethernet0/0
ip address 192.168.30.20 255.255.255.0
ip helper-address 172.16.1.21
no ip directed-broadcast
bridge-group 1
bridge-group 1 spanning-disabled
interface Group-Async1
ip unnumbered Ethernet0/0
encapsulation ppp
async dynamic routing
async mode interactive
peer default ip address pool dialup
no cdp enable
ppp authentication chap
group-range 33 48
ip local pool dialup 192.168.30.41 192.168.30.56
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
ip route 172.16.0.0 255.255.0.0 192.168.30.1
ip route 172.18.0.0 255.255.0.0 192.168.30.1
ip route 192.9.201.0 255.255.255.0 192.168.30.1
no ip http server
tacacs-server host 192.168.30.2 single-connection
tacacs-server key itnidworks
snmp-server engineID local xxxx
snmp-server community public RO
snmp-server community private RW
line con 0
password 7
login authentication no_tacacs
transport input none
line 33 48
exec-timeout 0 0
autoselect ppp
script dialer cisco-default
modem InOut
autocommand ppp
transport input all
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
password 7
end
06-06-2005 12:38 PM
With the information that you have provided it is difficult to know what is wrong. Several possibilities that occur to me would include:
- is it possible that the IP address in the config is not the correct address of the new server?
- is it possible that the tacacs key in the config is not the same as the key defined on the new server?
- is it possible that the new server does not recognize requests coming from this router at address 192.168.30.20?
- were the dial access users defined in a particular group on the old server and are they defined the same way on the new server?
It seems to me that a good place to start is with the logs and/or the ACS reports on the new server. Does the new server recognize the authentication requests from the router? If the server saw the request does it think that it authorized it? If the server did see the request but did not authorize it what does it have in the failed attempts report?
Tell us these things and we may be closer to finding the solution.
Rick
