acs 4.0 max sessions not working
rmolina71
hello,
i am having problem with max sessions feature.
we were working with the acs trial and works fine, after we make the installation of the licensed version of acs, we did it over the trial, and the feature is not working, we check everything again, and delete/add again the aaa client, we change the secret key, etc, but with no luck
the acs is logging tacacs+ data, the users appears with the start / stop records, where can i check some acs error?
or how can i debug it?
thanks
Raul Molina
rmolina71
helP?
darpotter
Level 5
Level 5
Sigh.. pre 4.0 you could look at the windows registry (where the logged in session data was stored) to troubleshoot.
Now its all locked away in a SQL database.
YOu'll need the TAC and (probably) escalated support from DEV to find out.
