ACS 4.1 multi method authentication
thetone69
Community Member
Hi folks,
if we have a current acs configured to authenticate users via RSA securid can the same user auths be done to a device that only supports Radius?
The Radius only works if I set the user auth to ACS internal database.
Cheers
Tony
Ivan Martinon
Level 11
Level 11
Hey Tony,
Since your device only support radius, you can use a Network Access Profile to match some set of conditions and apply some set of rules, for example, you can use the NAS-IP-Address attribute to match the ip address of this host from the Access-Request packet and tell that if this device comes to authenticate then authenticate to the local ACS DB, all other queries should be parsed normally. Take a look at the configuraiton guide of ACS particularly on the NAP section:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/user/NAPs.html
