ACS 5.2 Liscense problem
Angus Bishop
HI All ,
I have a  ACS 5.2 version installed on Vmware . I  purchased below  liscense
Product Name                  : L-CSACS-5-LRG-LIC=
Product Description         : L-CSACS-5-LRG-LIC= : ACS 5 Large Deployment License (Electronic Delivery)
When i am trying to upgrade the liscense i am getting an Error " Liscense file installation failed : The liscense file must contain single base liscense "
Please find the screenshot attached .
Please let me know how can i install the liscense
Angus
jrabinow
Level 7
Level 7
My guess is that you are trying to install a license file that contains both a base license and a large deployment license
Open you license file in an editor. Each license is about 5-6 lines begininng with word FEATURE
Check how many licenses you have and of which type as follows depending on word that appears after FEATURE
- ACSBase: Base license
- ACSLargeDeployment: Large deployment
If see both a base and large deployment license then can delete the lines for the base license and try and install large deployment license only
HI ,
The issue was i have not installed the base liscense the issue got resolved now .
Angus
Dear Angus Bishop
how you solve this problem ???
