ACS 5.2 problem with logs.
randy.klassen
Level 2
Level 2
Hi all,
I have 3 ACS servers placed throughout N. America. I it set up so that ACS01 is primary and ACS02 and ACS03 are secondary. When i look at the logs for passed/failed authentications in radius or tacacs I cannot see anything from ACS03 logging. This is weird because just a few weeks ago it worked perfectly. In fact, ACS03 is the most active server since this site is using it for wireless phones and tacacs and the other 2 are just using ACS for wireless networking. I went through the log settings and every server is set up the same as the others (except the primary) so it should be logging ACS03 the exact same as 01 and 02.
Anyway it seems like a small problem but i need the logs to work correctly to properly administrate security. Can anyone help with this? Or seen it before?
Thanks in advance,
Randy
randy.klassen
Level 2
Level 2
Found the issue. ACS01 somehow changed its timezone to UTC. just FYI if anyone has this same problem, check the console timezones
