acs 5.2 shell authorization sets
royalblues
Level 11
Level 11
Can someone point me to a guide on how to configure shell auth sets in 5.2
I have done it in 4.2 but can't seem to get it working in new version
Requirement is to just allow shut / no shut command but as soon as I give access to config terminal the user gets all access
Narayan
andamani
Please do the following:
Policy elements > Command Sets > Create
Give a name
Enter the grant condition , commands and arguments
Click on ADD
Click on Submit
Click on Access-policy > Device Default Access > Authorization > Customize
Customized results > Available:Select Command set > Move to selected
ok.
Select the rule to apply TACACS authorization on the default device admin authorization page.
In the results of the shell profile Command set . Click on Select and select the command set you created.
Click on Ok.
Hope this helps.
Anisha
P.S.: please mark this thread as answered if you feel your query is resolved. Do rate helpful posts.
