ACS 5.5 Monitoring and Report Viewer not working
petebardak1
ACS and AAA is working fine, but whenever I try to launch the Monitoring and Report Viewer on ACS v5.5 I get the a message saying "The monitoring and reports database is currently unavailable. Attempting to reconnect in 5 seconds. If problem persists, please contact your ACS administrator."
I tried stopping/starting ACS via CLI and reloading the whole box but it still comes up as unavailable.  Below is the current status.  Some processes are not running, does anyone know how to start these processes? I recently had to reinstall this appliance and restore from backup.  This is how it's been ever since.  Is there something else I should be addressing to resolve my issue?
pru-acs01/admin# show application status acs
ACS role: PRIMARY
Process 'database' running
Process 'management' running
Process 'runtime' running
Process 'ntpd' running
Process 'view-database' not monitored
Process 'view-jobmanager' not monitored
Process 'view-alertmanager' not monitored
Process 'view-collector' not monitored
Process 'view-logprocessor' not monitored
21 Replies 21
I tried that a few days ago but it didn't help.  I think my only option is to reload the OS and restore configs from backup.
I see. Can you Choose System Administration > Configuration > Global System Options > Trust Communication Settings. In case it's enabled, please disable it and give another try.
~ Jatin
~Jatin
Still not getting anywhere.  Getting
"ACS: Resource not found or internal server error"
ErrorCode: 500 has occured. Click here to get back to the server
When I click back to the server, I get the same error with
ErrorCode: 0 has occured. Click here to get back to the server
I think this is hopeless
Did you check the status of the service ( show app status acs) prior executing the "acs config-web-interface migration enable". Make sure ACS services are in running state and then test.
btw, what patch are you running on top of ACS 5.5 - this issue was not reproducible initially and the fixed was introduced in ACS 5.5p11 with some assumptions. Pls confirm the patch version.
~ Jatin
~Jatin
Not all services are up and running and reboots won't fix.  I use to have TAC support but this product went End of Support recently.
pru-acs01/admin# show app status acs
ACS role: PRIMARY
pru-acs01/admin# show application version acs Cisco ACS VERSION INFORMATION ----------------------------- Version : 5.5.0.46.8 Internal Build ID : B.723 Patches : 5-5-0-46-8
The required services are running fine. Looks like you have selected the "log-collector" as none that is why other services are not monitored. Can you apply the patch 11 and see if that makes any difference. Download patch from here
~ Jatin
~Jatin
Gagandeep Singh
I would suggest to reset the view database.
  1. a) In CLI type "acs-config"
   Enter GUI credentials
  1. b) type acsview replace cleandb command
Example : admin(config-acs)# acsview replace-cleandb
  1. c) Restart the ACS services.
Use the acsview replace-cleandb command to clean up the information in the ACS view database. This command removes all data from the ACS view database. That is, this command replaces the current database with a fresh view database.
Gagan
PS: rate it as correct if it helps!!!!
