ACS 5.5 System Alarm[Collector] Error
Maksim Urmanov
Good day, dear community
I'm experiencing problem with acs 5.5 with installed latest patch. Suddenly secondary acs started to show problem which is shown on screenshot, everything is working fine, that's why is this message so strange for me, can anybody suggest me, what should I check?
edwardcollins7
Turn on Management debug:
acs-config
<enter the GUI username>
<enter the password>
debug-log mgmt level debug
and collect the support bundle from the ACS after the event has occurred again
and share it, looking for the Monitoring and reporting collector log is what I am looking for.
Rate if Useful :)
Sharing knowledge makes you Immortal.
Ed
Hello, Edward,
Thank you for you help, I collected appropriate bundle, and find the log which you ask me, I also read this file, and found that database can't find listener but I don't know how to run it again, but this is just my own opinion.
Thank you in advance
just want to know,
did the alarm caused any impact ? maybe like you can't generate some report or something else?
please confirm
