ACS browser problem with IE11
I cant see the MAC filter configured in ACS using IExplorer11 but if i use IE10 i can see this filter. Is there any problem in WebUI using IE11??
Gagandeep Singh
If you can send the screenshot from ACS, which option are you looking for.
Also let me know the ACS version.
We dont see these two filters in IE11.  But in IE10 we see the filters.
Another bug in ACS with IE11???
There is no such bug for it. If you could confirm your ACS version.
We can check for compatibility of browsers.
Otherwise need to correct the database of ACS.
Marvin Rhoads
ACS 5.5 or higher should support IE11.
In general, ACS - especially earlier 5.x versions - has been very particular about using only supported browsers. It was as bad as causing database corruption when making changes using an unsupported browser version!
