ACS certificate problem
david.kamarad
Community Member
I try to change authentication on my ACS 3.1 and W2k server from EAP-MD5 to EAP-TLS. I created certification authority. Then i created client certification and export the key file with password. When I write this values to ACS ( path to certificate and path to key file and password) the ACS write:
Private key you've selected doesn't fit to this certificate.
I don't understand where is the problem becouse the key file is definitly from this certificate.
Thanks for help
David
vmoopeung
Level 11
Level 11
I guess ACS is not detecting the service called Server running. You can log into the server with the username Administrator and then reinstall ACS. Make sure that the Server service is running when you install ACS. Looks like ACS is not installed properly.
