ACS config Problem
wasiimcisco
Level 7
Level 7
I have ACS solution engine, I made a NDG on ACS and add AAA server and AAA client. I also made a user in default group 1. The same user exist
in rotuer local database just on the safe side. But I am not able to see any activitiy in ACS reporting window,
not able to see any logged user in ACS.
The following is the configuration that I did on ACS engine and router
aaa authentication login default group tacacs+ local
aaa authorization exec authorization group tacacs+ local
aaa accounting commands 15 accounting start-stop group tacacs+
username cisco password cisco123
tacacs-server host 172.28.31.132
tacacs-server key <tacacs-shared-key>
ip tacacs source-interface gig 0/1
Jagdeep Gambhir
Level 11
Level 11
You mean you can authenticate fine but do not see any command accounting ? If that is the case,then pls note that Command accounting logs are stroed in tacacs administration logs.
Also there is a known issue on ver 4.1.1 and we need to apply patch ACS 4.1.1.23.5 to fix the command accounting issue.
Patch for appliance is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
Patch Name : ACS 4.1.1.23.5 accumulative patch
That should fix the issue,
~JG
but I am not able to see complete logging of all commands that I am using during the session. I configure the following things on router
aaa new-model
aaa authentication login default group radius local
aaa authorization exec authorization group radius
aaa accounting commands 15 accounting start-stop group radius
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
radius-server host 172.28.31.132
radius-server key waridtel0321
ip radius source-interface gig 0/1
Please tell me how i can see which activities user has performed during the session. detail of command.
Can i use tacacs for authentication and radius for accounting. I tried it but it didnt work for me.
Please guide I will be very greatful to you.
in Tacacs accounting CSV file, it shows me only login time, user id and service shell, i want to see detail of command that user has used during the session.
I have attached both CSV files that i got when trying with tacacs and radius for accounting.
Command accounting is only possible via Tacacs and not radius.
So you need to use tacacs and these logs would be logged in tacacs administration logs.
~JG
Do rate helpful posts
