ACS Engine Solution /database issue
prekursor000
Community Member
Can ACS Engine SOlution ver 3.2 have its own internal database for AAA, or it has to be connected to the external DB. / What is the advantage of having ACS 3.2 engine solution, instad of using software version? thank you very much
john.gudmann
Level 3
Level 3
I would thing so. I believe that the only deferens is that ACS Engine Solution vs software is that you get all in one (software and hardware all together.)
PS. I have read that ODBC database is not availably in the Engine S.
