ACS Install problem
walderhaug
I have big issues reinstalling an ACS server (4.0 on Win 2003).
I get a lot of errormessages like:
"V:\ismg_israel_acs\Acs\Crypto\init.c line 194, CryptAqquireContext failed ...."
I have no drives called V currently mapped, and the name of that directory does definately not sound familiar. It does not exist on this server at all.
I have used the same install files on this and other servers before without any problems.
I have also searched the registry for some of the strings in the error message, without finding them.
This is really giving me a headache!
Hopefully there is someone in this community that can help me out on this.
darpotter
Level 10
Level 10
The V: drive isnt yours. This refers to the location on the server where ACS was compiled during it build.
It could be as a result of a partially broken uninstall of a previous ACS version. You could try getting hold of the clean utility (on the cd?)
Or do a ?findstr /I CiscoSecure *.*? in your Application Data\...Microsoft..\Crypto\RSA\... and delete the file with the Cisco Secure container text.
Then you should be good to go.
darpotter
Level 10
Level 10
