ACS problem with ppp/ccp
I use Cisco Secure ACS with Tacas+ to authenticate dialin users on a Cisco2610.
While doing authentication locally on the router everything works fine:
Windows users dial in, are validated, get a callback and even multilink with compression.
When ACS is involved, I cannot connect with ccp enabled.
I used the Interfaces/New Services to add Protocol=ppp and Service=ccp. As soon as this is activated (on users or groups) users can no longer connect to the dialin-router.
The Windows-Client stops when waiting for callback.
Without the parameter (PPP/CCP) activated everythings works fine even with callback and multilink controlled by ACS.
Anybody any hints on this ???
umedryk
Level 11
Level 11
I feel this may not be a problem with your ACS server. Which OS are you using ? Do you have all the patches required for this ?
what OS do you mean?
The one running ACS: it is Win2003 patched up to date
The clients: different OS but should not be the problem, because authenticating againts the router (without ACS involved) works fine.
Maybe the problem is related to another question I posted here and got some helpful hints. (See ACS dialin problem).
I will report as soon as testing is done.
regards
Hubert
Hi all,
I could solve my problem with authentication againts Actice Directory but the above mentioned problem still persits.
Anybody any helpful hints??
regards
Hubert
