ACS Problem
ismail884
I have 2 ACS SE, one primary and the other secondary. when I've configured them, all operation seems completed correctly, clients can authenticate successfully. but when I restart them,no authentication is performed, I cheked the Network Configuration page in the Primary ACS and I detect that the following is added to the AAA servers"self with an address 127.0.0.1". the address is unchangeable neither the Secret key.
any one have some idea?
thanks
acharyr123
Level 7
Level 7
When u add the ACS in AAA Server option at Network Configuration u will get "Self" for ACS with the IP of the device...not 127.0.0.1
It seems both these devices are nt configured properly in active/standby mode.
Please try to add the same with the exact IP of the primary ACS..It should work!!!
Rate if it helps!!!
I've used the Engine Recovery CD. and I reconfigured the ACS.this time I verified that all thing is working properly. I configured the IP address and I restart the ACS many times.
thank you
Ismail
