ACS question with connecting on a switch
muratayas
we have two different Version of ACS Appliance v3.3 and v4.0.
Now when i connect in v3.3 to a Switch then i been not in the enable modus and with v4.0 i been in the enable modus. I look the User setting the Group settings and all the other settings in ACS but i see not the different. I have now the problem, when the user has connect to the a switch, he have not a messages with password change, i think maybe is this the reason.
regards,
murat ayas
Look at the group settings for that user on both ACS 3.3 and 4.0, and see if there are any differences there. If the user is granted privilege level 15 when ACS 4.0 is authenticating, but not when ACS 3.3 is authenticating, then perhaps the TACACS+ settings on the 3.3 box are different.
Thank You Javier,
i see that in the group setting under TACACS+ Settings-->Privilege level was 15. I remove that and now is the same behavier.
regards,
Murat
