ACS Solution Engine 4.2 Private Key File
Michael Wong
We generate CSR on an ACS 4.2 SE, and specifiy the private key file as ACS42.pvk.
The CSR is sent to CA to request a server certificate. And we can install the certificate with private key file in the ACS SE.
However, we see the private key file is stored inside the ACS SE and no way to export it.
We need to export the private key because we want to install the same server certificate on another ACS SE.
Please advise how to export the private key file from the ACS SE.
Yudong Wu
Level 7
Level 7
I don't think there is a way to export private key file. But you can do a backup and then retore it in the other ACS. The backup should include both cert and private key.
