acs upgrade problems
adriatikb
Level 3
Level 3
after upgrade of acs 4.1 the tacacs+ administration( on reports section) database does not populate with commands that administrators enter on cisco routers.
any ide ?
thanks.
Premdeep Banga
Level 10
Level 10
Apply the latest patch for 4.1(1) Build 23 or get ACS version 4.1(3) Build 12. There's a known bug for this.
ACS for windows:
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
ACS SE:
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Prem
thank you prem , latest patch for 4.1(1) Build 23 which is Patch Acs-4.1.1.23.5-SW is the solution.
