ACS: using local users as fallback for AD
Wassim Aouadi
Level 8
Level 8
I have ACS 5.1 configured to authenticate users based on Active Directory. I have configured wired 802.1x too, with machine authentication enabled on ACS.
When I login with credentials that exist in AD, it works fine. Then I configured Windows Authentication to ask for credentials (popup window). But I experience network disconnection when I login with a local account even though I entered correct AD credentials.
I want to do the following: for an account that exist on the machine being authenticated (non-AD account), ACS should check its local database and reply with authentication success if it finds it, so the user is granted network connectivity.
I heard about Identity Sequence in ACS. But I still don't see the right configuration,
any help?
thanks
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
jrabinow
Level 11
Level 11
You can configure an indentity sequence that will first access the local data base for user authentication and, if the user does not exist in the local database it can then proceed to authenticate the user against AD
Configuration can be done as follows:
1) Go to Users and Identity Stores > Identity Store Sequences and press Create
2) Enter a name for the sequence and then Password Based Authentication Method. Will see a list called "Authentication and Attribute Retrieval Search List". Include first Internal Users and then AD1 in "Selected" list. Press "submit" and sequence will be create
3) Select the Indentity sequence as the result in the idnetity policy you are using. for example if you are using "Default Network Access" access service that is created by default go to:
Access Policies > Access Services > Default Network Access > Identity and select the indentity sequence you created in step 1) as the Identity Source
jrabinow
Level 11
Level 11
I wanted the opposite, i.e. if user does not exist in AD then proceed to local database. It worked.
Thanks for giving me these steps
