ACS v5.3 Timeout connection is not working
I'm trying to configure a timeout for network connection, but when it suppose to disconnect client, it's not working.  Is it possible to do this??
Only works when the client is connecting and is denied if the time is not valid.  But how could I do this if the client is already connected, enable re-authentication??
Juan Carlos Arias
michael mearlon
Are you trying to keep the connection live for a short term?
Hello Michael, sorry but don't understand your question, if I´m trying to keep connection live??  What I´m looking for is that the client has to have network connection only on time hours defined, on working hours.
My problem is that for connection already running, the client is not disconnected, but for new users trying to connect at no time work hours, it's blocked, it's correct this way.
Thanks for your comments,
Juan Carlos Arias
