ACS5 / ISE: PEAP authentication - first machine then user
Johannes Luther
Level 4
Level 4
Hi board,
I have a simple question regarding AAA with ISE or ACS5 and PEAP.
As we all know, the big disadvantage in PEAP is, that you cannot enforce that non-company property authenticates to the network.
Example:
Windows Domain - PEAP machine and user authentication. During Windows GINA, the machine account is used - after login, the user account is used.
If I bring my own iPad to the company, I just have to enable WLAN, enter my Domain credentials and voila! I'm in!
Some companies want to restrict the network only for company equipment.
So a simple solution to this is, EAP-TLS - but we all know that some guys don't want to build up a full blown PKI....
So here's the question:
Is is possible to enforce an authentication order in ISE or ACS.
If a authentication request for a certain client MAC address comes in (Calling station ID), then this identity has to authenticate with a machine account first (prefix "host\") and only after the machine authentication succeeded, the user authentication is allowed.
If someone want to login with a user-account, then this should not be possible, if there was not a former machine authentication.
So is this possible with ACS or ISE?
Thanks in advance!
Tarik Admani
Johannes,
You can prevent ipads from connecting by forcing machine authentication check in the user authentication policy.
http://www.cisco.com/en/US/docs/security/ise/1.0/user_guide/ise10_authz_polprfls.html#wp1116684
You can also leverage the profiling feature in ISE to reject the apple devices from accessing the network.
Tarik Admani
*Please rate helpful posts*
Tarik Admani
Johannes,
Tarik Admani
This is exactely what I've been searching for!
Thank you!
One more thing.... this is not available for ACS, right?
Profiling is not, but machine authentication with machine access restrictions is.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.3/user/guide/users_id_stores.html#wp1254965
Tarik Admani
