04-07-2010 04:03 AM - edited 03-10-2019 05:03 PM
i have a problem with the command on Cisco Device when i configure a range of Interface then i have this messages:
% Authorization failed.
EYAMPLE: 1
rw-sw-19#conf t
Enter configuration commands, one per line. End with CNTL/Z.
rw-sw-19(config)#interface range Fa0/3 - 24
rw-sw-19(config-if-range)#switchport voice vlan 1201
rw-sw-19(config-if-range)#power inline auto
rw-sw-19(config-if-range)#end
EYAMPLE: 2
rw-sw-03(config)#interface range Fa0/2 - 48
rw-sw-03(config-if-range)#switchport voice vlan 1501
rw-sw-03(config-if-range)#power inline auto
rw-sw-03(config-if-range)#end
rw-sw-03#
I can reproduce this problem as often as you want.
Just enter the same commands.
The number of “ % Authorization failed” may differ, but you should be able to get them.
I have notice this, because I use a script to configure the VoIP VLAN on these switch.
I notice that this problem has ONLY happen on switch which are POE.
With the switch which are not POE, I did not see this problem up to now.
I look the Group setup on the ACS and see that the enable options is : Max Privilege for any AAA Client Level 15
Can it be an Tacacs problem or is this maybe a cisco device problem.
regards,
murat ayas
04-07-2010 11:39 AM
Do we see any hits in failed attempts of ACS? When ACS denies any request we get "Command Authorization failed" but here we see % Authorization failed.
Please enable debug and see if it tries to send authorization request to ACS or not. If there are no authorization debug then issue is with device it self.
debug tacacs
debug aaa authorization
~JG
Do rate helpful posts
04-09-2010 05:33 AM
