Aruba Wireless Controller and ISE
Jeffrey Jones
Level 5
Level 5
Ok, so we have the basic part working, but CoA is failing to respond to the request from the ISE server. Any ideas anyone?
Jeff
22 Replies 22
Hi jjonessec1969,
any change on this? Can you now disclose the steps to make ISE and Aruba work together? :)
Thank you in advance.
Best Regards,
molnar.erik
aman.diwakar
Interesting that CoA is working with Aruba, we were under the impression it was not. Any challenges you want to share with us in getting that integration in place?
Naveen Kumar
Level 4
Level 4
it doesnt have to be inline to get Aruba to work, Aruba's issue is they currently have a bug in CoA so sometimes you will see CoA failures. Working with Aruba technical support on it now.
I was working on an Aruba and ISE deployment. The endpoint needed to be postured, but it never worked properly.
We saw that the endpoint was authenticated against ISE and the radius accept packet was received in the aruba controller. However, the iPEP session was never triggered and the endpoint never got access to the redirecction link. Is there an example of Aruba and iPEP you can share?
Ravi Singh
Level 7
Level 7
This might help you out.
"Certain  advanced use cases, such as those that involve posture assessment,  profiling, and web authentication, are not consistently available with  non-Cisco devices or may provide limited functionality, and are  therefore not supported with non-Cisco devices. In addition, certain  other advanced functions like central web authentication (CWA), Change  of Authorization (CoA), Security Group Access, and downloadable ACLs,  are only supported on Cisco devices.""
http://www.cisco.com/en/US/docs/security/ise/1.1.1/compatibility/ise_sdt.html
manjeets
Level 3
Level 3
We only support LWA guest on the Aruba Controller with ISE. The captive portal is hosted on the Aruba controller.
Additionally the AUP on the controller is just a link to the AUP page and there is no check box to select. By logging in you agree to the AUP implicitly. You can read the text of the AUP by clicking the link.
See the following VoD on how we can get preactivated guests to work on an Aruba controller.
http://ecm-link.cisco.com/ecm/view/objectId/090dcae184b05aef/versionLabel/CURRENT
Also the ISE-Aruba integration guide is here: http://ecm-link.cisco.com/ecm/view/objectId/090dcae184a2f348/versionLabel/CURRENT
Links seem to be broken. Could you verify please?
