Assigning privilege level using Radius
sweeann
Community Member
I'm trying to assigned a privilege level on a Cisco router via Radius. I'm using the Cisco Secure ACS (Windows 2K).
I have set the privilege level to 15. But when I telnet to the router, I always get the router> prompt instead of the router# prompt.
How can I configured the Radius/router so that when I get successfully authenticated, the router# prompt is shown.
I've configured the router as below:
aaa authentication login vtymethod group radius enable
aaa authorization exec vtymethod group radius local
radius-server host 202.x.x.195 auth-port 1645 acct-port 1646 key cisco
line vty 0 4
login authentication vtymethod
On the Radius, I've configured as below:
In the group settings for IETF Radius attributes, the Service-Type is set to Nas Prompt.
Also in the group settings, I've checked the Cisco-av-pair with the following configured: shell:priv-lvl=15.
Is there something I'm missing.
Appreciate the help.
Thanks.
sweeann
dmholmes000
Frequent Visitor
Frequent Visitor
I believe adding the following line to your AAA configuration will allow a user authenticated through ACS to login directly to enabled mode:
aaa authorization exec vtymethod group radius if-authenticated
Hope this helps,
-d
Tried the suggestion above but I'm still getting the router> prompt instead of going directly to enable mode.
sweeann
sweeann
Community Member
Just an update:
I've configured wrongly on the network configuration in the ACS. I've chosen Radius (IETF) instead of Radius (Cisco IOS/PIX). Once I changed it to Radius (Cisco IOS/PIX) I was able to assigned the privilege level.
Thanks all,
sweeann
Im curious... what is the perceived benefit of using RADIUS instead of TACACS+ ?
Given that ACS supports both and that T+ is a superior protocol for device admin.
I once heard someone mutter that T+ was proprietry... but all they were doing was sending (effectively) T+ av-pairs via a Cisco RADIUS VSAs. Not significantly different one could argue!
