Attributes problem of ACS
slavon
I need to send different RADIUS attribute value (filter-id) to user depending on where a request come from. If from local NAS it should be one value, if from other ACS it should be another. But attrubute can be set only to user or group of users it can not be set to device and a user can be a member only of one group so I can't see how it could be done...
sghosh
Hi ,
You are correct the filter-id attribute can be applied as per-user or per-group basis and not as per the NAS they dial into.
Sujit
Is there any workaround?
