Auth-proxy with NAT issue (aironet wireless)
nickpowers
I have setup auth-proxy on a 2651 router that contacts the cisco ACS using Tacacs+. On the Cisco ACS i am currently using the ciscosecure database currently. I have a cisco 1130AG wireless AP that provides wireless access to our users. The 2651 is also acting as a DHCP and NAT server for the wireless users. My issue is when the user is given the auth-proxy login screen and types in his/her login information and clicks ok, I get a popup and inside that popup I always receive an error message "HTTP 500 - Internal Server Error Page cannot be displayed"
When I debug tacacs, and auth-proxy on the 2651 I get nothing coming up on the screen. I have verified that tacacs packets are moving from the 2651 to the Cisco ACS server but not back. Does this error ring a bell for anyone? Below is the config from my 2651:
CC2T-2651-02#show run
Building configuration...
Current configuration : 2460 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname CC2T-2651-02
aaa new-model
aaa group server tacacs+ TRENT_WL
server ###.###.###.###
aaa authentication login con local
aaa authentication login telnet local
aaa authorization auth-proxy default group tacacs+
aaa accounting auth-proxy default start-stop group tacacs+
enable secret xxx
username admin password 0 ######
ip subnet-zero
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1 192.168.1.25
ip dhcp pool trent_pool
network 192.168.1.0 255.255.255.0
domain-name trentu.ca
dns-server ###.###.###.###
default-router 192.168.1.1
ip auth-proxy auth-proxy-banner ^C Welcome <p>Please login: ^C
ip auth-proxy auth-cache-time 3
ip auth-proxy name PROXY_LIST http list 10
ip audit notify log
ip audit po max-events 100
call rsvp-sync
interface FastEthernet0/0
description outside access
ip address ###.###.###.### 255.255.255.252
ip access-group 101 out
ip nat outside
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet0/1
description inside wireless LAN
ip access-group 102 in
ip access-group 102 out
ip nat inside
ip auth-proxy PROXY_LIST
no ip mroute-cache
duplex auto
speed auto
no mop enabled
ip nat pool trent_nat ###.###.###.### ###.###.###.### prefix-length 24
ip nat inside source list 1 pool trent_nat overload
ip classless
ip route 0.0.0.0 0.0.0.0 ###.###.###.###
ip http server
ip http access-class 11
ip http authentication aaa
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 10 permit any
access-list 11 deny any
access-list 100 permit tcp ###.###.###.### 0.0.0.255 any eq telnet
access-list 100 permit tcp host ###.###.###.### any eq telnet log
access-list 100 permit tcp host ###.###.###.### eq tacacs any
access-list 100 deny ip any any log
access-list 101 permit tcp any any eq tacacs log
access-list 101 permit ip any any
access-list 102 permit ip any host 192.168.1.34 log
access-list 102 permit ip any any log
snmp-server community ##### RO
snmp-server enable traps tty
tacacs-server host ###.###.###.###
tacacs-server directed-request
tacacs-server key ####
dial-peer cor custom
line con 0
login authentication con
line aux 0
line vty 0 4
access-class 100 in
password ##########
login authentication telnet
end
Thank you,
nickpowers
Found the solution: The Cisco ACS was blocking access to it. So note to anyone else, if you receive a popup with an "Internal HTTP Error" message during auth-proxy, check that the router/firewall can connect to the RADIUS/TACACS server.
