Authentication Problem with ACS 5.2 Using LDAP
zara6500dolfin
HI!
I  want to use LDAP for connecting to active directory but I get this   Error from ACS 5.2 ( 22056 subject not found in the applicable identity  stores).Is there anyone who can HELP me?
I used this configuration in ACS 5.2:
Users and Identity Stores / External identity store / ldap / Directory Organization
Subject ObjectClass : User
Subject Name attribute ; sAMAccountName
Group ObjectClass : Group
Group Map Attribute : MemberOf
jrabinow
Level 7
Level 7
Two questions:
- did you press "Test Bind to Server" from LDAP "Server Connection" tab and "Test Configuration" from "Directory Organization" tab?
- did you select the LDAP database as the result in the identity policy?
HI jrabinow
Thanks for your answer
yes I tested it and the result was successful I also add ldap database in the identity store. but the error is the same.
