BYOD Password less solution flow challenges
kshah2589
Level 3
Level 3
We have already configured the SSID in Meraki dashboard for our BYOD network to use an ISE captive portal redirected to Microsoft login page configured with SAML SSO authentication. the flow is Meraki > to ISE > to Azure IDP.
While testing the BYOD flow, time to time we are facing the following error in screen shot. we are not sure what could be the reason. Is there any way we can remediate the issue?
we already have following websites in Meraki walled garden as per the documents, are we missing anything else?
login.microsoftonline.com
aadcdn.microsoftonline-p.com
aadcdn.msauth.net
Let me know if any suggestions.
Kunal
balaji.bandi
is the DNS works as expected ?
at the same time have you checked the URL on other browser (not safari ?)
BB
Thanks balaji for the prompt reply.
I am not sure what you mean exactly by DNS work as expected but the flows are as follows.
1). user connects to SSID, the user receives internal IP and external DNS server info >>>>>> then browser receives portal redirect URL resolves to internal ISE IP by the external DNS server [which is happening perfectly ok] >>>> then ISE internally redirect browsers to Microsoft login page for authentication. that's where we notice the error.
2). we also notice the same error with android phones in other browser.
Kunal
