Check Point Identity Collector and Cisco ISE Integration using PxGrid
henokk601
Hi All
I tried to Integrate Checkpoint Identity collector and CISCO ISE PxGrid I generated the needful certificate and on the Check Point Identity collector it shows me Admin approval but on the CISCO ISE there is no server waiting for approval.
Please let me know if you have any ideas of how to go about solving this issue.
2 Accepted Solutions
Nancy Saini
I would suggest taking a packet capture on ISE and check SSL handshake on TCP 8910 for Identity collector.
What is the version of ISE you are using? If 3.x then check if Identity collector is using pxGrid 2.0 as pxGrid 1.0 is not supported from ISE 3.x.
5 Replies 5
DNS is good?
Nancy Saini
I am looking for the procedures on having Check Point Identity Collector to integrate with pxGrid 2.0. Please can someone give me a link or procedure on doing this
gaigl
Level 3
Level 3
we've an Identity Collector successfully connected to our ISE, I see the events are counting up, but I can't find any Information, how to publish Groups (from AD the ISE is connected) to the Identity Collector.
Could you give me a hint?
Thank you
Karl
charwinz
This issue should be regarding the certificate, suggest installing Java_Runtime_Environment_(64bit)_v8_Update_311 when you use Openssl to general the certificates.
