Cisco acs 1120 upgrade to 4.2.1.15 help
sansarav720e
Hi All,
            I have cisco 1120 appliance downgrade from acs 5.0 to acs 4.2.0.124 , I need to upgrade to acs 4.2.1.15 . Does cisco 1120 acs appliance supports 4.2.1.15 , How can i upgrade to 4.2.1.15 from 4.2.0.124 .
            It requires any distribution server for upgrade process . Please suggest on this , Thank you
HTH Regards Santhosh Saravanan
Jatin Katyal
Yes, you can upgrade it to 4.2.1.15 and you can download the version from the below listed link;
http://tools.cisco.com/squish/d4e4A
Here are the files you need to download:
ACSse-Upgrade-Pkg-acs-v4.2.1.15-K9.zip
ACSse-Upgrade-Pkg-appl-mng-v4.2.1.15-K9.zip
NOTE: Please apply the management upgrade first and then software upgrade. ..
Distribution server is a machine from where you can upload the patch onto the Cisco Secure ACS Appliance so If you will download the version on your laptop and upload it from there then that would be distribution server (Nothing special)
Upgrade an appliance to 4.2.1.15
http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2.1/Installation_Guide/solution_engine/upgap.html#wp1148376
Hope this helps.
Rgds,  Jatin
Do rate helpful posts~
~Jatin
Jatin Katyal
Hope this helps.
Rgds,  Jatin
~Jatin
Jatin ,
               Thanx for your posting , I has downloaded the mentioned upgradable patch and did upgradation to my cisco appliance , Thank for your support on this ..
