Cisco ACS 4.2 Max Auth/Autentication devices limit.
cargomez
Hi guys.
Anyone can clarify me how many devices can an ACS 4.2 work with TACACS+ ?.
Is there any limit?, and if exists, which is it and where does Cisco publishes it.
Spent a whole morning and no success reaching for the info.
Ty in advance.
Carlos.
Waris Hussain
I did a search for this and based of that i found that ACS 4.2 Solution can support up 35000 device. Here is the link  from which I got the information :
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5712/ps5338/qa_c67-453393.html
An appliance-based Cisco Secure ACS server follows  at a minimum the same scalability performance of a Windows-based Cisco  Secure ACS server. Cisco Secure ACS guidelines and performance analysis  show that each ACS server can support anywhere from 20,000 to 80,000  users per server and can scale to support up to 35,000 devices,  depending on configuration, platform, and usage scenarios
However internal we have also seen it is recomended  to use 500 device per NDG.
I hope this helps.
Waris Hussain.
Waris Hussain
I hope this helps.
Waris Hussain.
Helped me a lot.
Thank you.
Best regards,
Carlos.
sjbdallas
Just to clarify:  I get the impression that the original question is about how many devices can authenticate at any one time rather than how many devices the database can hold.  If you're asking about concurrent authentications, I think this post has details: https://supportforums.cisco.com/message/3038224#3038224
