Cisco ACS 5.3 - Radius attributes and 'Device Administration/Shell Profiles'
phipham-equens
Can anyone help me with the following ?
Under 'Policy Elements/Authorization and Permissions/Network Access/Authorization profiles' I have defined a profile and the following Attribute:
Attribute = F5-LTM-User-Role
Type = Unsigned Interger 32
Value = 300.
My question is:
How can I define the same as above using 'Device Administration/Shell Profiles' ?
There is a Custom Attributes tab but I cannot figure out how to specify the 'Type' field. (Under Custom Attributes tab there is only space for 2 fields and not 3 fields).
Tarik Admani
Just for my understanding are you trying to use tacacs or radius?
Shell profiles are used for tacacs and authorization profiles are used for radius.
Tarik
Tarik Admani
Tarik
Thanks for your help !
(I use Radius for access to a device).
Not a problem, please do not forget to mark this as resolved so future users will be able to find this was resolved.
thanks,
Tarik Admani
*Please rate helpful posts*
