Cisco ACS + TACACS is not working for ASR1001
mothukuri
Hi Experts ,
I am new to Cisco ACS .TACACS is configured on ASR routers and we have necessary config done on Cisco ACS.
I would like to check command to see which ports are opened and also reason for authentication failures on ASR1001.
When i tried to do telnet ACS ip with port 49 , connection was refused .Does it means services are not running on Cisco ACS ?
ACS has 5.8.0 .
telnet 10.41.29.20 49
Trying 10.41.29.20...
Connected to 10.41.29.20.
Escape character is '^]'.
Connection closed by foreign host.
9 Replies 9
you need to add below
line vty 0 4
login
password < >
input transport telnet
username <> password <>
enable password <>  <<<<<<- this mandatory please dont forget this password
then try access
we have below config on ASR1001 and its not accessible using TACACS credentials.
I would like to know the command to check which ports are opened on Cisco ACS other than "show ports " and also why are we getting "Connection closed by foreign host" when I tried telnet 10.41.29.20 49 from one of the Switch which is in the same subnet range.
aaa group server tacacs+ TACACS
server name ACS1
server name ACS2
server name ACS3
ip vrf forwarding Mgmt-intf
ip tacacs source-interface GigabitEthernet0
aaa authentication login default group TACACS local
aaa authentication login VTYAUTHENT group TACACS local
aaa authentication login CONAUTHENT group TACACS local
aaa authentication login console local
aaa authentication enable default group TACACS enable
aaa authorization console
aaa authorization exec default if-authenticated
aaa authorization exec VTYAUTHOR group TACACS local
aaa authorization exec CONAUTHOR group TACACS local
aaa authorization commands 15 default group TACACS local
aaa accounting exec default stop-only group TACACS
aaa accounting commands 15 default stop-only group TACACS
tacacs-server directed-request
tacacs server ACS1
address ipv4 10.41.29.20
key XXXXXXXXXXXX
timeout 2
tacacs server ACS2
address ipv4 10.31.47.46
key XXXXXXXXXXX
line con 0
stopbits 1
line vty 0 4
exec-timeout 30 0
logging synchronous
login authentication VTYAUTHENT
transport preferred ssh
transport input ssh
the transport is ssh and you try telent so you need to make vty accept both
transport input ssh telnet <<- only this need
MHM
I am checking whether port 49 is opened on Cisco ACS end using telnet 10.41.29.20 49 , its not for logging into Cisco ACS.Hope you got my point.
On windows /Linux usually we will check ports opened using telnet server ip and port number right.
is there any way to check port 49 is running on Cisco ACS from Cli
you want to access to ASR or check if port is open ? you post is about how we can access to ASR not to check port open or not
MHM
main problem is that console credentials are not working to change the config on ASR1001.We are working on TACACS issue and noticed that credentials are not working while logging into ASR1001.Firewall team has confirmed that policy is opened on the firewall and no issues from their end.They have asked me to check whether port 49 is working and also required services are working on Cisco ACS or not .Need guidance from Experts of Cisco ACS to isolate the problem from Cisco ACS end before pinching firewall team again.
mothukuri
firewall  engineer had tried to check connection of Cisco ACS on port 49 from firewall itself but its getting closed immediately .
You config ASR to accept only ssh and you use telnet sure ASR is close connect.
Also both ssh and telnet not use port 49!!
MHM
this lab for you
there are many log error message appear
I list the three common
1- there is ACL drop the connection, you can see destination unreachable, meaning there is ACL OR FW drop the tcp connect
2- you can access to device but the password is wrong, here if device ask for password then you can access to device but the passowrd OR ISE (AAA) is wrong or missing
3- closed by foreign host , this when you dont config the device for telnet
