Cisco Identity Services Engine Field Engineer ... How I need to renew ?
descalante2007
Two years ago I did two exams, 650-473 (now retired) and 650-474 ...
What exams I need to do to renew my "specialization" ?
I need to do 500-254 ISE and repeat 650-474?
I know my current specialization is valid until October 15th
Regards.
Gustavo Novais
yes, it is exactly that. I had to do the same - repeat the 802.1X exam and do the new ISE.
Do keep track of your certification status, because I also had a few problems with the renewal process being reset after the exams were made...
Good luck.
Gustavo
Venkatesh Attuluri
You need to take ISE 500-254  exam
