Cisco ise 1.3 - eap-tls user + machine auth problem
Augustgood
Hi all,
My eap-tls authentication and authorization policy do not work , this my rule:
Authentication:
WIREDDEVICE:
Device Type EQUALS Device Type#All Device Types#Swicth Cisco
AND
Radius:NAS-Port-Type EQUALS Ethernet
Authorization:
WIRED-MACHINE if (Wired_802.1X AND ADTP2:ExternalGroups EQUALS tp2.it/Users/Domain Computers
AND Network Access:EapTunnel EQUALS PEAP
AND Network Access:EapAuthentication EQUALS EAP-TLS )
then WIRED_AD_ONLY
 WIRED-USER if (Wired_802.1X AND ADTP2:ExternalGroups EQUALS tp2.it/Users/Domain Users
AND Network Access:WasMachineAuthenticated EQUALS True
then WIRED_PERMIT_ALL
Default if no matches, then DenyAccess
This is my error generated from ISE:
11001Received RADIUS Access-Request
 11017RADIUS created a new session
 15049Evaluating Policy Group
 15008Evaluating Service Selection Policy
 15048Queried PIP - DEVICE.Device Type
 15048Queried PIP - Radius.Service-Type
 15048Queried PIP - Radius.NAS-Port-Type
 15048Queried PIP - Network Access.UseCase
 15006Matched Default Rule
 11507Extracted EAP-Response/Identity
 12500Prepared EAP-Request proposing EAP-TLS with challenge
 12625Valid EAP-Key-Name attribute received
 11006Returned RADIUS Access-Challenge
 11018RADIUS is re-using an existing session
 12502Extracted EAP-Response containing EAP-TLS challenge-response and accepting EAP-TLS as negotiated
 12800Extracted first TLS record; TLS handshake started
 12805Extracted TLS ClientHello message
 12806Prepared TLS ServerHello message
 12807Prepared TLS Certificate message
 12809Prepared TLS CertificateRequest message
 12505Prepared EAP-Request with another EAP-TLS challenge
 12504Extracted EAP-Response containing EAP-TLS challenge-response
 12571ISE will continue to CRL verification if it is configured for specific CA - certificate for Users
 12571ISE will continue to CRL verification if it is configured for specific CA - certificate for tp2-AD2K8-CA
 12811Extracted TLS Certificate message containing client certificate
 12812Extracted TLS ClientKeyExchange message
 12813Extracted TLS CertificateVerify message
 12804Extracted TLS Finished message
 12801Prepared TLS ChangeCipherSpec message
 12802Prepared TLS Finished message
 12816TLS handshake succeeded
 12509EAP-TLS full handshake finished successfully
 15041Evaluating Identity Policy
 22072Selected identity source sequence - TP2_SEQ
 22071Identity name is taken from AD account Implicit UPN
 15013Selected Identity Source - All_AD_Join_Points
 24432Looking up user in Active Directory - All_AD_Join_Points
 24325Resolving identity - CN=stefano nicoletti,CN=Users,DC=tp2,DC=it, stefano nicoletti, Users, st.nicoletti@tp2.it
 24313Search for matching accounts at join point - tp2.it
 24362Client certificate matches AD account certificate - st.nicoletti@tp2.it
 24319Single matching account found in forest - tp2.it
 24315Single matching account found in domain - tp2.it
 24323Identity resolution detected single matching account
 24700Identity resolution by certificate succeeded - All_AD_Join_Points
 22037Authentication Passed
 12506EAP-TLS authentication succeeded
 24423ISE has not been able to confirm previous successful machine authentication
 15036Evaluating Authorization Policy
 15004Matched rule - Default
 15016Selected Authorization Profile - DenyAccess
 15039Rejected per authorization profile
 11503Prepared EAP-Success
 11003Returned RADIUS Access-Reject
------ iF i snff the traffic on pc--- see attach file ----
This is the error reported on swicth:
750x-nac#show authentication sessions interface Gi1/0/10: auth_bend_request -> auth_bend_request
*Mar  1 02:39:00.506: dot1x-sm(Gi1/0/10): 0x68000019:auth_bend_request_request_action called
*Mar  1 02:39:00.506: dot1x-sm(Gi1/0/10): 0x68000019:auth_bend_request_enter called
*Mar  1 02:39:00.506: dot1x-ev(Gi1/0/10): Sending EAPOL packet to 1060.4b4a.29fb
*Mar  1 02:39:00.506: dot1x-ev(Gi1/0/10): Role determination not required
*Mar  1 02:39:00.506: dot1x-registry:registry:dot1x_ether_macaddr called
*Mar  1 02:39:00.506: dot1x-ev(Gi1/0/10): Sending o
3750x-nac#show authentication sessions interface ut EAPOL packet
*Mar  1 02:39:00.506: EAPOL pak dump Tx
*Mar  1 02:39:00.506: EAPOL Version: 0x3  type: 0x0  length: 0x0005
*Mar  1 02:39:00.506: EAP code: 0x1  id: 0xFF length: 0x0005 type: 0x1
*Mar  1 02:39:00.506: dot1x-packet(Gi1/0/10): EAPOL packet sent to client 0x68000019 (1060.4b4a.29fb)
*Mar  1 02:39:10.790: dot1x-ev(Gi1/0/10): Received an EAP Timeout
*Mar  1 02:39:10.799: dot1x-sm(Gi1/0/10): Posting EAP_TIMEOUT for 0x68000019
*Mar  1 02:39:10.799:     dot1x_auth_bend Gi1/0/10: during stat
3750x-nac#show authentication sessions interface e auth_bend_request, got event 12(eapTimeout)
*Mar  1 02:39:10.799: @@@ dot1x_auth_bend Gi1/0/10: auth_bend_request -> auth_bend_timeout
*Mar  1 02:39:10.799: dot1x-sm(Gi1/0/10): 0x68000019:auth_bend_timeout_enter called
*Mar  1 02:39:10.799: dot1x-sm(Gi1/0/10): 0x68000019:auth_bend_request_timeout_action called
*Mar  1 02:39:10.799:     dot1x_auth_bend Gi1/0/10: idle during state auth_bend_timeout
*Mar  1 02:39:10.799: @@@ dot1x_auth_bend Gi1/0/10: auth_bend_timeout -> auth_bend_idle
*Mar  1 02:39:1
3750x-nac#show authentication sessions interface 0.799: dot1x-sm(Gi1/0/10): 0x68000019:auth_bend_idle_enter called
*Mar  1 02:39:10.799: dot1x-sm(Gi1/0/10): Posting AUTH_TIMEOUT on Client 0x68000019
*Mar  1 02:39:10.799:     dot1x_auth Gi1/0/10: during state auth_authenticating, got event 14(authTimeout)
*Mar  1 02:39:10.799: @@@ dot1x_auth Gi1/0/10: auth_authenticating -> auth_authc_result
*Mar  1 02:39:10.799: dot1x-sm(Gi1/0/10): 0x68000019:auth_authenticating_exit called
*Mar  1 02:39:10.799: dot1x-sm(Gi1/0/10): 0x68000019:auth_authc_result_enter
3750x-nac#show authentication sessions interface  called
*Mar  1 02:39:10.799: %DOT1X-5-FAIL: Authentication failed for client (1060.4b4a.29fb) on Interface Gi1/0/10 AuditSessionID
*Mar  1 02:39:10.799: dot1x-ev(Gi1/0/10): Sending event (2) to Auth Mgr for 1060.4b4a.29fb
*Mar  1 02:39:10.799: %AUTHMGR-7-RESULT: Authentication result 'timeout' from 'dot1x' for client (1060.4b4a.29fb) on Interface Gi1/0/10 AuditSessionID 0AD2010A000000180090C942
*Mar  1 02:39:10.799: dot1x-ev(Gi1/0/10): Received Authz fail for the client  0x68000019 (1060.4b4a.29fb)
3750x-nac#show authentication sessions interface *Mar  1 02:39:10.799: dot1x-ev(Gi1/0/10): Deleting client 0x68000019 (1060.4b4a.29fb)
*Mar  1 02:39:10.799: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (1060.4b4a.29fb) on Interface Gi1/0/10 AuditSessionID 0AD2010A000000180090C942
*Mar  1 02:39:10.799: %AUTHMGR-5-START: Starting 'mab' for client (1060.4b4a.29fb) on Interface Gi1/0/10 AuditSessionID 0AD2010A000000180090C942
*Mar  1 02:39:10.799: dot1x-sm(Gi1/0/10): Posting_AUTHZ_FAIL on Client 0x68000019
Who can help ?? this is a lab environment and i don't find the solution...
The certificate are on pc for client and machine , AD join work perfectly,  i changed junmbo mtu.. but do not workk.....:(
any help apprecciated....:)
Augustgood
The proble can be the binary comparison, on AD i haven't bind a certificate to host.... ?
jan.nielsen
Level 7
Level 7
Why do you have PEAP in your authz rules, if your doing EAP-TLS?, this will never match, you can't do both in the same rule.
Also, don't expect "WasMachineAuthenticated" to work properly, it's not a very stable feature. You should look into Cisco AnyConnect NAM and EAP-Chaining.
then WIRED_AD_ONLY
I think jan is right, choose EAP-TLS or PEAP, not both.
However your rule is failing on the WasMachineAuthenticated attribute. This is not a very good feature and pretty much fails when using more than one PSN. The problem being machine authc happens with one PSN and gets logged, user authc happens with the other and the machine log authc that is checked does not replicate between PSNs and so fails.
