Cisco Ise 1.3 with Wireless Flex-connect supported function
Augustgood
My environment is formed by cisco Ise 1.3 and wireless LAP in flex-connect mode, these features are supported?
AAA Basic Functions
profiling
posturing
VLAN Override
ACL Override
Guest Provisioning
from trustsec 2.0 doc this features are not supported ? someone try this feature ?
Marvin Rhoads
Those all work with ISE 1.3 and FlexConnect WLANs.
You do need the right ISE license - the Mobility (Wireless) license type will cover it all. If you have wired and wireless then you need to have Base (for most of the features) + Plus (for Profiling) + Apex (for Posturing).
Marvin Rhoads
Ok thank you..:)
