Cisco ISE 2.1 Settings Keep Changing
agapitca19
Is there a way to view in ISE who's making changes and what those actual changes are? Like an audit changes for ISE itself. I am not referring to TACACS log.
Thanks!
Gagandeep Singh
You can go into Operations > Report > Audit > Change Configuration Audit.
Gagan
ps : mark as correct answer if it helps!!!!
Gagandeep Singh
Gagan
