Cisco ISE 2.2 BYOD onboarding and certificates problem
Hey guys
our company is using a Cisco ISE 2.2 and BYOD on a dual SSID design and so far it works good. But now I would like to use a public certificate for the captive portal and I have some problems with understanding the concept.
Actual Design
Cisco ISE 2.2
Hostname: ise-server-01.enterprise.local
Certificates:
1. Corporate PKI used as CA (named Enterprise CA, signs certificates for Domain enterprise.local)
2. Server certificate for Admin and Portal usage signed for ise-server-01.enterprise.local
3. BYOD uses ISE internal CA in standalone mode (not subordinate of Enterprise CA) to generate and sign client certificates
Goal
Use a wildcard certificate for public enterprise domain enterprise.com on BYOD captive portal, so the user does not get a certificate warning, when connecting a new device to the byod onboarding SSID.
Tested
1. Installed the Public Root CA (eg. DigiCert) on ISE Trusted Certificates store
2. Installed the wildcard certificate for *.enterprise.com on ISE for Portal usage (BYOD captive portal)
3. Configured a redirect to byod.enterprise.com, so the clients get redirected to the BYOD captive portal
-> So far, so good, the client does not get a certificate warning anymore, because the captive portal answers on byod.enterprise.com:
See attachment ise-byod-1.jpg.
When the user completes the BYOD process, the Cisco Network Assistent gets downloaded and it tries to connect to byod.enterprise.com:
See attachment ise-byod-2.jpg.
BUT now the user gets presented the ISE certificate for the Admin usage with ise-server-01.enterprise.local:
See attachment ise-byod-3.jpg.
1. Why is the Admin usage certificate presented (not even the EAP usage, because this is another / third certificate!)
2. If the user continues, a SSL error occurs while generating and creating the BYOD client certificate:
See attachment ise-byod-4.jpg.
Maybe others have to deal with this and can clearify, why the Admin usage certificate is used in this process and if I have to use the wildcard certificte *.enterprise.com as Admin usage certificate (this means, I will have to move the ISE server from domain enterprise.local to enterprise.com!)?
Thanks a lot in advance and best regards
Dominic
Octavian Szolga
Level 4
Level 4
Hi Dominic,
I don't have a link from the official documentation, but I do have a picture from a TAC presentation regarding ISE :)
Octavian
ipagliani
Ciao,
did you resolve? How ?
