Cisco ISE and and management of Extreme VOSS Switches
dal
Level 3
Level 3
Hi.
I'm struggling to log into some Extreme VOSS switches when using Cisco ISE as the radius server.
ISE says login is OK, but the switch says the username/password is wrong.
Has anyone successfully set up this combination?
thomas
Typically TACACS+ is used for device administration and RADIUS is for access control on the individual ports so that might be your problem. Without any configuration examples, it will be difficult for anyone to understand what you're doing or provide any suggestions beyond links to resources.
How to Ask The Community for Help
https://cs.co/ise-berg#extreme
